System UI tuner help
Sam Rogers1
So I just opted into the beta program today, and best i can tell everything works fine. However, my system UI tuner only had the same two options from nougat, and not what I am reading should be there now. I remove it and re-added it, removed it restarted then re-added it, but to no avail. Any advice, it seems all the cool stuff for Android O involves they for now.
They removed all the other cool stuff in the 3rd beta the other day 😐
