System UI Tuner
wilmah
59
So I updated my 5x through the beta registration. Loving it so far. I can't seem to turn on the UI Tuner with the gear icon on quick settings though.
Anyone else notice this? I've already enabled developer settings- not sure if that has anything to do with it.
Have you changed the Animation settings in the Developer Options? If so, change them back to normal and try again.
Ahh- that did it. I had all my animations shut off in the developer settings. Thanks a lot!
Great! I learned that little tidbit from Javier P, one of our other Ambassadors.:cool:
Try to switch off your Developer Options then enable the System UI Tuner. Then re-enable the Developer Options if you wish. Hope this helps!
DanishDanuu
