System UID's inconsistent
amigo mi problema creo que es mas serio, borr� todo de mi tabla android 4.0, pero todo, pues le d� formato tanto a la sd como a la memoria interna, ahora solo se queda en el mensaje android...... que puedo hacer, no logro instalar ni el recovery ni nada.....
sorry son, don't speak Spanish
I had the same problem. I installed ESET antivirus, made a scan and deleted 'gamezone'.
Then I went to 'Titanium backup' batch actions and cleared 'orphan data'.
The problem solved. Do not know which caused the rectification.
Cheers__
Hello,
my sister had this problem today. Her phone was optimizing system apps, and it took a long time, so she just turned it off, and after rebooting this showed up. I am now fixing it. The problem is in a system app, so wiping /data here most likely wouldn't help, that would need things a bit more developed.
sukarisw12
