System update for Sprint HTC One
Now that the update has been out for a bit, is it worth taking? I'm currently on 3.04
Sent from my HTCONE using AC Forums mobile app
I have a LG G2 also, now you talk about battery life. That bad Dude sips the battery its unbelievable.
Couldn't agree more. So envious of my daughters G2
If you are talking about the latest 'fixer' update, then Definitely YES.
The latest update fixed everything that the previous one broke.
Sent from my RCT6378W2
I never took the original update that ended in .5 because of the issues.
It seems like this update is the original plus the fixes
My Evo lte Filling the shoes of my HTC One
Well the only good thing about the first update is that it put the Signal Bars back to show the Call Signal Strength and 1x Strength instead of the 3G or 4G strength.
My personal suggestion is to take the update.
Okay. Very odd. Right after .6 loaded I updated my profile and PRL. worked as it should. THought that issue was resolved. I just tried to do it again and I am now getting the same error messages I had with the .5 release. Anyone else?
Front page says Sprint update is now available. Just checked, and nothing. Anyone get it yet?
Re: system update
I have the same problem after I updated the system, my htc one won't stay connect to my car Bluetooth
Anyone know how to fix this
Thanks
Got it. Anyone have a list of the changes. I've noticed that I don't have the option of no lock screen anymore (not liking that) but you can turn BlinkFeed off which is a plus for some.
sent from my stealth black HTC OnE
Yay
Much faster/smoother, new tv remote interface, lock screen widgets. Love it so far.
Yes, I got both of the Sprint 'Maintance' updates.
I also just download the Kit Kat update.
Hey guys.. I need help. How did any of you guys get the 4.4 update? Because I can't find check for updates in settings on my HTC one currently on 4.3
redmercer
