System Update for Verizon S7 Edge
Abby Normal
88
I just got a notice of a system update.....
A quick look around here and I don't see any info on it.......
Of course some times I can't find my car keys too ...LOL
Anyone know anything a new system update, mine just appeared this morning.....
Thanks in advance
Re: System Update
How big is it? It may be a monthly security update.
Re: System Update
AT&T version says I'm up to date...got the August security update about 10 days ago...
Re: System Update
yeah I've got one, 296mb says it improves bluetooth, nfc as well as adding samsung cloud. hopefully it sorts out my phone radio/wifi battery drain as well.
Re: System Update
Correction,,, it is now on the screen and saying SOFTWARE update.
containing enhancements and improvements to the Samsung Galaxy S7 Edge including Android security updates.
Software Version MMB29.G935VVRU2APG5
HD voice improvements. new Galaxy features, such as support for NextRadio and Barcode Beaming for UPC codes
Listen to live FM radio on your phone. You will be able to see hear and react to local radio programs on the Edge.
NextRadio is supposed to use less battery than others...........
Guess that's about it..........can't see anywhere for what the size is.....
I got it yesterday, but haven't seen any changes. The phone overheated a few times while doing the update, though. First time I've seen this phone go into cooling mode.
Re: System Update
Verizon removes (hides) Samsung cloud on the note 7 so I'm sure they do the same for the edge. They want people to use their cloud service which is highly inadequate.
When I got my phone a few days ago, there were 3 updates in a row on the phone. The phone heated up pretty good but now it is as cool as a cucumber. VZW version here.
Once I updated the phone it will not charge from my car charger. My wife has same phone and she didn't update and can charge. Once I plug in my phone it says moisture detected.
repairphone12
