System update notification wont go away
  • Start date Start date
A
AC Question
Im currently on 6.0.1 build number mob30m and its constantly saying that the system update has downloaded and wants me to install it even after ive just installed it, whats going on?
What happens when you select install again? It could be a new/different update. Check the build number of the update against your current one.
If it is the same, try forcing google play services to stop and reboot the phone (settings -> application manager -> google play services -> force stop).
If that does nothing, you can disable notifications from google play services and it should be gone. You can un-check that box from the same page using the instructions above.
Boot your phone into recovery mode and select wipe cache partition..wipe it reboot your phone now if the message appears just tap onto it.It will say to install update press ok..installation will be failed as tou have cleared the downloaded software so it will say installation failed and wont reappear..
