System update turned nexus 10 into brick (that makes annoying noise)
Martin Smith9
I just today 24th Dec 2014, accepted the latest system update on my android nexus 10.
It is now broken. It is a total brick.
It just reboots over and over, displaying the robot with warning sign with "No Command", waits 10 seconds, then reboots again. Everytime it does this it makes a noise, i cannot even turn it off.
I guess it will keep doing that until there is no battery life left.
Help.
Help.
When it is at the "No Command" sign, it must be in the recovery. At that point, hold the power button and click volume up. You should be prompted with a set of options. First, you could try to wipe the cache and see if that helps (it will not delete your data) otherwise, you could do a factory reset (which will delete your data).
ecomranx07
