T-Mobile Pushing out Android System update
Mine also updated automatically last night without me knowing.
Also I noticed that after the update it changed my wifi setting to shut off wifi when screen is off
So you guys check to make sure that yours is still set to keep wifi on when screen off
Same here, didn't receive the update yet and I am still on 10d which means it didn't install over night
Same here. If it doesn't push by tomorrow morning I will probably manually update.
'This mandatory update improves software stability.'
https://support.t-mobile.com/docs/DOC-22421
Really wish they would put out an official changelog. Bothers me that I have absolutely no idea what changes are being made.
How do you manually update? Does t-mobile have a tool or something?
Does it bring back multi user support? Every review, including the one posted here, said the G4 supported multi user. I'm not happy that it is stripped out of the t-mobile version.
Very interesting to hear what's in this. Hopefully it fixes some quirks and VZW will follow suit.
Mine just automatically downloaded during the night. It is possible that is what happened to you and others, and you may not even know it.
That's what I assume happened to mine - mandatory update. Like an incubus.
Has anyone actually been asked to install the update? Or are the devices "silently" updating?
For those that have received the update. How is battery life and lag/responsiveness after the update?
I just got the update last night. Woke up to find WiFi calling is now working. I was getting an error message before.
The ones who don't have it yet -- Have you tried manually checking just to see if it shows? I am just curious :).
vdacau
