T-Mobile USA - Lolipop and VoLTE?
In anticipation of stock Loli, I went ahead and un-flashed my phone; got tired of waiting and put CM12 back on last night, and with my luck 5.0 will drop in a few days now. If it does... you're welcome. ( :
I just don't understand it at all. Lollipop is working fine on G3's all across the county/world including Sprint, AT&T and even some Verizon as well. How the hell is the T-Mo version so far behind??
Good question... Now you just gotta wait for a answer which won't come anytime soon...
How to enable VoLTE: navigate to the phone application I'm the LG G3 T-Mobile and type 3845#*851# that pills up a hidden menu.
Note: the (851) number is the LG G3 Model Number go to settings to find out what your Model number is.
Its old and it does NOT work yet!
A day or two ago tmonews.com picked up on the switch to "T-mobile testing" stage - and then stated they have no idea how long it will be in that stage. That site has become so useless since the original blogger left. No inside info from TMO and nothing better than can be found right in this thread, LOL!
Yep, I used to get everything T-Mo from T-Monews, most of the time I'd go into a store knowing more than their sales staff! Though I think David, the original editor, works for T-Mobile's social media department now. https://twitter.com/davidj
But T-Monews isn't even close to what it was when he was there. Now it seems like it is just press releases and re-posts from other blogs.
Well, hopefully we are getting closer now, looks like someone started to make some edits to the Software and Updates page (the updates are not published yet, but usually when these get edited it means they are preparing to announce a new software download).
Here's direct link too https://support.t-mobile.com/docs/DOC-11935
Maybe we are just a few days/about a week away? Next week maybe?
No change - still in testing. The rumored Lolipop update on 3/31 is false.
Had a feeling it was. When none of the blogs picked up the story, it seemed too good to be true. A lot of times there is a leak at least 24 hours before an update that helps to corroborate the claims.
Just installed the update with the LGMobile Support tool. It might say you are up to date. But goto >Options >Flash Recovery. That will update you to version D85120b.
Running 5.0.1
jafar
