Taking Calls Using Edge Display Portion
socacola
Active member
Jul 3, 2013
32
I have recently switched from my Note 4 Edge to S6 Edge. I love the phone and the form factor. Only thing I'm missing is the ability to take calls on the edge display. It was specially helpful when using GPS and the call details would be on the edge display on the Note not hindering what's happening on the screen. The S6 does not have this capability. Samsung should really implement these features from Note 4 to S6 Edge.
I know the S6 Edge does not have the size of the Note's display, but it can be done. Especially if your multi tasking.
I would have figured that Samsung would have implemented the same features from the Note 4 Edge to the S6 Edge. Hopefully they will add it in a future update.
I agree...I hope this will get implemented, but unfortunately the edge on the s6 is so different than the note, so I wouldn't hold my breath.
All that is needed is a pop up call receiver that is on the edge of the screen. Since the S6 edges are part of the main display however it would have to be superimposed over regular screen real estate. The note edge had extra screen area outside of the normal area.
