TaskIt: A new Todo/Project management app
@WareER4X: There is already a button to take you to the home screen. Just tap on the house icon on the far left of the bottom toolbar.
Also, I've been tweaking the widget. Scrolling will for sure be implemented. However, the next build will have the ability to change the view on the widget (i.e. Today, Future, All, etc.) and it will also have the ability to filter by context.
Sorry, I should have been more specific. The home button isn't there when you open a task be tapping on its notification. The only buttons at the bottom are "complete", "edit" and "delete". Still I just found that hitting the back button seems to take me to the main task screen. At least it did this time. When I was doing that yesterday, it would take me back to the home screen of the phone. Oh well, thanks for the feedback.
-SR-
I guess I misunderstood. So, when responding to a notification (or just viewing the task's summary), you would like a button to return you to main list? I'll see if that's doable.
Cs Kredivo
