Teeter game
If it is not in your downloads listing, it didnt download. If you have a file browser (Astro!) browse to your Download (not Downloads) folder, should be there if phone grabbed it.
Teeter is a cool game that usually comes by default in many HTC smart phones. If not included in your phone then you can download it from the market.
I downloaded the Teeter-7.apk to my razr, but it does not work properly on my hd screen. All the bars and holes are further away on the screen so I can't navigate without falling into an unseen hole. I really like this game and want to have it. Does anyone know of a version that will function properly on the razr?
HELLO AND PLEASE HELP ME :-)
How can I get this for my iPhone? Is there a way? Please help - I love this game as well and I have been searching everywhere and I can't find it. thanks:)
Monika
New member, HTC Evo 3D/Sprint, looking for Teeter game for this phone. Phone is box stock. I had Teeter on an old Hero, liked lot. I just downloaded the ap from the dropbox link above & installed it. No joy, ball misses visible walls, hits invisible ones, won't roll to edges of screen. Uninstalled. >> Is there a Teeter download compatible w/Evo 3D?
Yah that link should only be used if you don't have a HTC phone. I just got a HTC EVO Design 4G, I was able to download it from the "HTC Hub" app that's pre-installed on the phone. They also have a ton free apps and cool widgets on there too :)
Sent from my HTC Kingdom using Tapatalk 2
Thanks much, vincentallen2, I shall head there and try it.
No prob, hope you enjoy the game again.
Suggestion though, clear data then uninstall the previous teeter app before you download it again from HTC Hub. This makes sure that those format problems don't reappear.
My record ! 3:27 seconds ! And the others records are close, 3:29, 3:33 !!! Is anybody better ? :)
Can someone upload another link to the apk? The other links have been down for a while. :(
Sent from my Galaxy Nexus using Tapatalk 2, because Sprint users must be punished for not having GSM attenas and rapid updates.
Adekanmbi
