tethering help usb
hansgroter
Active member
Jun 3, 2012
40
Hey I recently upgraded from a thunderbolt to the rezound did it before the 28th so I'm not under verizons new share plan well with the thunderbolt easytether and pdanet worked fine. I activated the rezound this morning and it no longer connects was wondering what teathering apps work for the rezound
Pdanet works fine on mine...
Sent from my ADR6425LVW using Android Central Forums
I disagree with clockwork tether. I do not get a reply from the dev after numerous attempts. I use easy tether pro and it is flawless.
Some tethering apps block secure pages or throttle you after a certain trial period expires.
Laurie2Megan
