Tethering to Android phone via Wifi hotspot
People are getting confused as in Wi-Fi types. Yes the K-fire connects to a wifi signal but only in an infrastructure mode such as a hot spot such as your home router, mifi device, McD's, starbucks, etc etc. Will not connect via Wifi in ad-hoc mode such as a smartphone wifi tether apps such as barnacle or Wifi tether. Some apps will let you use infratructure mode but on Verizon it will require you to sign into a Verizon hot spot account if you have one.
Again... depends on what WiFi hotspot software you are using.
As I've said, mine works fine using the SQLEditor/Wifi modification without signing in on my Droid Bionic. The Fire runs off this without issue.
What its this mod that you speak of? Any links?
He obviously doesn't know, but you can do a Google search for it. There is even a 3 day old blog article that has a You Tube of how easy it is.
But please don't come back and want me to re-search for it.
Mine connects fine to my Droid X running SSX2.2 using wireless tether.
*customized tapatalk signature*
MisterVoltio
