Text messaging problem after ROM flash?
sirk0rebreg
64
Flashed superclean 0.4 and adrynalyns 12/30 kernel and for some reason when I send a text it shows up blank and I am not receiving any texts?
Sent from my SCH-I500 using Tapatalk
try a different kernel
were you on DL09 build?
did you try restarting your phone?
OK I will give that a shot with the different kernel. I did restart my phone I will try that again as well. Yes I was on the DL09 build
I need to buy you a beer man!
Just flashed geekniks stupidfast 1.54 and rebooted and no such luck with the texts yet?
No need just hit the thanks button, and help others when they need out it
Strange before you flashed the rom. Did you wipe data and cache?
I believe so...I just checked my about phone on settings and baseband is dl09 but build is showing di01 is that how it should look?
I may have to start again from scratch and do it all over again...
That's the problem , both should be the same. Either you didn't update or you didn't flash the DL09 version of super clean
Reactions: sirk0rebreg
OK I flashed it in ROM manager must have screwed it up somehow LOL, I will just restore and flash it in clockwork mod this time...thanks man
There is a thread in fascinate roms and hacks that lists compatible roms. Try those
ok i restored, flashed a new compatible ROM, themed the phone so i am all set now thanks for the help and quick replies...the baseband and build are now matching at DL09 in the about phone settings and the text messaging is working again!
OK great , glad thats cleaned up :)
tombwiz14
