Text size changes randomly
it happens when adaptive battery is enabled. it will change the resolution to save battery
Well. I think I figured it out. It appears to be some sort of issue with Bluetooth. When I go tin my car this morning and was reading an email which was fine. I closed it and started my car and connected my Bluetooth. While I waited for the car to warm I opened Instagram and it was enlarged. I thought it odd so it hit me. Only thing different was Bluetooth. I turned off my Bluetooth, closed Instagram and when the Bluetooth was off and disconnected it was back to normal. I turn it back on, closed Instagram and when I reopened it? You guess it - Enlarged. Facebook? enlarged. Email? enlarged. Bluetooth on and off several times and what happens? Enlarged when on and normal when off. Not sure how this affects screen size but I am pretty sure its my issue.
That is super odd. I'm not sure how Bluetooth would affect your text size but it sure seems like that is what is going on in your case. I haven't had this issue when connecting to my car or headphones. Do you have another Bluetooth device you could connnet to to see if it happens with that as well? Then maybe you could isolate to just your car or see if it's Bluetooth in general that causes this to happen.
Tried today. Happens with car and Jaybird Headphones
Have a new s10+ Ok phone. Nothing mindblowing about it. However, at random times, with no reason nor rhyme the font size enlarges and stays there until it randomly changes back. There is no particular function or app that I open to make it happen. It happens on the home screen, facebook, maps, text app (google messages) and really all apps I open.
Anyone have the issue and/or a fix???
Had the same issue but on a regular s10.
Just figured it out while reading the thread. When I activate the battery saver the apps text size goes nuts, but when I dissable it it is all good.
Hopefully this can help other s10 pals.
Hi mustang. Did you solve your problem? I am having the same issues. I bought this s10 plus on loan scheme. And now I am very upset. I am using Bixby routines. Did you solve your problem?
Sonfollower28
