- May 20, 2013
- 77
- 0
- 0
Who is the retard at Samsung that decided to use the VOLUME ROCKER to determine the font size in the native texting application in the S4? I like the font size at the smallest setting but in order to keep the font setting at the smallest size I need to permanently leave the following setting on "USE VOLUME KEY TO CHANGE TEXT SIZE". If I uncheck it after I use the rocker to bring the text size down to the smallest setting the font size resets to the larger size! So every time I am using my texting application I can't change the volume on my music player, media player, phone call, NOTHING. All it does it make my text big and small. I constantly find myself backing out of the native texting program just to adjust the volume on my phone. Amazingly stupid feature. I think it must be a bug that the text size resets to the larger size after unchecking the use volume key to adjust text size feature. Because nobody could possibly be that dumb to design it this way. Anyone know of a fix? I don't want to use a third party texting app (had some bad experiences with them). I like a simple, clean application as the native one is... but would prefer to have smaller text. I'm not blind (yet). Thanks in advance.
