Text tone problem?
kurpaige
65
Anyone having problem with text ringtones? I don't get text tones or vibrates at all. Google Voice work but not text.
I've noticed this as well. Not sure what's going on.
Sent from my XT1080 using Tapatalk 4
I want to say I had this problem on day one, but playing around with the volume settings seemed to fix it. (No sarcasm)
Double check all your volume levels. Remember that notification volumes aren't linked to the volume rocker so they might be turned down even when your ringer is turned up. Also try setting a new notification sound from within the messaging app settings.
DIdn't know that, will check as soon as I can get back to my phone. Hope that's all it is cause everything else seems to work fine.
This works! Strange that this time they did that. I turn off all notification sounds. The only sounds I want are ring tones and SMS/MMS
mengatasipinkartudebitbni
