The included TurboCharger 25 is one piece (not brick+cable)
so, if the cable eventually starts to fray, or otherwise disintegrate, warranty will, or won't cover it?
I guess the few micro USB cables I've had do that were cheap...
--sent from neglected rural America
Re: Charger block/cable is one piece?
This has been confirmed by Motorola. Using a lower gauge USB cable could possibly impact charging speed and damage the phone, the wire, or the charger itself so they went with a one piece unit to avoid issues. I think it's a smart idea.
I'm not sure I understand the comment in the OP for the need to carry two cables.
There are non USB cables used for other portable devices that are two pieces to mitigate potential bend/damage issues at the base of the brick. It will be interesting to see how folk's batteries hold out that use the fast charge all the time (9-10 months). Motorola is being very aggressive :) Far more than Samsung with their fast charging.
Cable design seems fine, so probably no harm no foul.
Can we please get over the notion that Quick Charge is going to ruin your battery? I have a Droid Turbo that has only been charged on a Motorola turbo charger since the day it was released, and it stays on the charger all night.(will be a year in Oct) My battery is just fine and still last as long as it did the first week. Motorola and Qualcomm have both directly answered that question on their web sites. They unequivocally state it will not harm your battery. The software and hardware used in quick charge is optimized for the rate a battery can intake a charge.
This ^^^^^. The quick charger only accelerates charging at the bottom end. Example 10% to 60%. After the phone huts a certain percentage, the charging process slows down significantly. That is why in order to get the "10 hours of battery life from 15 min charging" Motorola states your battery has to be mostly depleted.
What is the difference between turbocharger15 and turbocharger25.
Does both are same.
And i am using moto x play
Does both works fine in that
njira
