The Official Body Glove Snap On Case Review Now At The Forum Store! YES A Kickstand!
Thanks for the review Ross!
Between this case and the Seidio Active X, which do you prefer and why?
Thanks!
Thanks!
I own an Active X case and quite frankly I like this Body Glove case better. After using it for awhile I really don't like the rubber case part covering the switch gear on the X. I also really like the flip out kick stand of the Body Glove. The X is a great case too, but its really more for hard core droppers and abusers IMO. ;)
I own an Active X case and quite frankly I like this Body Glove case better. I really don't like the rubber case part covering the switch gear on the X. I also really like the flip out kick stand of the Body Glove. The X is a great case too, but its really more for hard core droppers and abusers IMO. ;)
The only thing I don't like about this body glove case is that it exposes the screen outward when you have it on your belt clipped in. I'm always leaning up on hard surfaces at work and I see the screen getting cracked with it that way. Considering I don't have insurance on my phone, I am now sure that the active x is the case for me. Thanks for your help Ross!
Thats a good point but I never clip the phone to by belt because whenever I try it no matter what case I use I always manage to knock the phone off when sitting or getting into the car. I always clip my phone backward into one of my front pockets this way if it falls it goes into the pocket and not the street. Give it a try no matter what case you use.
Can you guys think of a spring clip holster that would be compatible with this case?
Also has anyone noticed any loosening of the slider mechanism with this? One of the reviews on Amazon mentioned loosening of the slider when removing the case because it was so hard to take off. That sounded more like it was more user inflicted. Thanks.
Sent from my SPH-D700 using Tapatalk
I don't think so. It is a snug fit but I never had a problem removing it. If its a bit loose then the phone can get damaged by the case moving on the phones surfaces and scratching the phone. As with all snap on cases caution has to be taken when removing the case but really you just have to use common sense and you wont damage anything. FYI the case will fit the Seidio ActiveX clip I just tried it.
Thanks! I was especially curios about the Active X clip holster. I'm going to order it now.
jmarshallcleaning
