The problem I have with this phone is that when it goes into power savings mode, the seconds hand
jeslevine
114
disappears. For those that want to time things, for instance within 60 Seconds, it will go into battery saving mode, and you lose that information.
That's because it takes a huge amount of power to display the second hand. It may not seem like it, but it means the watch's internal circuits have to "wake up" 60 times more often for each passing minute. Think about that for a moment...
As stated here ( Optimizing Performance and Battery Life | Android Developers ), "To maximize battery life, use animations sparingly. Even a blinking colon wakes up the CPU with every blink and hurts battery life."
If you need to time something, use the stock stopwatch app or download one from the app store.
Thanks N4Newbie. That makes sense, but it would be nice if they had an option to set a timer for a certain number of seconds before it goes into ambient mode.
It is a beautiful watch.
When I had my Zenwatch I remember getting an app that would control how long it would take before it would go to ambient mode. Might be Staylit Wear. Not sure if that app works on this version of Android Wear but you might want to check it out. Battery will drain quicker.
sokitmo1
