The Way It looks An SD Card Slot On The DNA Is Possible With Help From A Butterfly!
Someone mentioned in a previous thread that it occupies the same space as the SIM card on the US model. though hypothetically, they could have found room elsewhere on the device (e.g. the bottom).
They say you would have to replace the camera board with the Butterfly board that has the SD pocket mounted to it. Then you need to replace the back cover with the butterfly part because it has the cut out for the SD card door. BUT then I read somewhere after posting this that the butterfly battery door wont fit the DNA its a little longer.
How bout not screw with it verizon and just release the butterfly here.
Sent from my ADR6350 using Tapatalk 2
rannypoker
