[Theme][Swype]I'm taking requests May, 31 2011
I just tried to do what you suggested. everytime I try and flash the Buffaloes theme it gives me an error
E: cant open/sdcard/buffalos.zip
(bad)
Installation Aborted
Very frustrating because I was able to flash the weird face theme earlier. Not sure why this new one is not working
the swype fix is just an unthemed swype incase you didnt like the tsm swype. you are using the wrong clock work. flash the latest cwm the flash other stuff.
isnt the latest clockwork the one labeled cwm-recovery-ALL-3-30?
no, the latest cwm is from times_infinity & will only flash edify script. You should be able to flash the swype fix with cwm 3-30, I did. Otherwise you can find the new cwm in JaeKar99's thread on the stickies
Sent from the shark tank using Tapatalk
I flashed the latest and greatest CWM from times_infinity....Voodoo CWM 3.X....Still getting the same error as before. Possibly a bad download? I have tried it twice now, once with CWM 2.5.X and now with the new CWM 3.0.X and still the same issue. I have downloaded the file twice as well from the link. Any more ideas?
i dont know man. try another swype and see what happens
So I may have an incompatible version of swype? why would it work before though with the weird face theme you made? Does Jae have different versions of Swype in his thread? Thanks for everything though. hopefully I can get it figured out
i just want to know what happens when you flash another swype.
the weird face theme you have in post 2 works just fine.....just when I try and flash the buffaloes theme is when I get the message....should I try a couple more that you have on post 2? Is it possible that theme got corrupt somehow?
could be. i will post a new one in the morning.
ok, buffalos is fixed. looks like a bad upload. but its good now.
Mike, did you try it on your phone? I downloaded it again fresh and still having the same issue. Gives me the same error when flashing.
EDIT: I flashed the Atlanta Braves themed swype no problems....dont know what it is with the buffalos theme but it is a no go everytime. I have also flashed the weird face theme with no problems. I am guessing it has something to do with the buffalos file.
Mike...just noticed something while trying to redownload the buffalos theme. The file is labeled as 13.43MB for instance, but when I go to download it only shows as 13.2MB. I checked the other 2 files I have downloaded and they are the same as far as file size and download size. Maybe this is the problem. Dont know, just grasping for straws
yeah i flashed it and it worked fine. the first file was giving me the same errors but the second one worked.
i just redownloaded it and it is acting stupid again. hang on.
try it now
Reactions: dhdmart
mcheck
