[Themes] Custom ICS
I was sorta curious aboot the launcher? if I installed it would I have both the stock one running and the go one? or would stock be disabled? fyi also ive noticed in the power things in the pull down notification menu the left two icons dissapear after I toggle them on/off...they do reappear when they are on though they just dissapear when turned off....but I will reflash and try again ^.^
The wifi and bluetooth?
When off they should be a gray color and when on they should be white.
Sent from my LG-VM701 using Tapatalk
And about the launcher, they'll both be running, but its a simple step on just force clossing or stopping the stock launcher. I didn't improvise the go launcher because everyone has their own prefrence on what they like to use. I use go launcher so that's why its used in the screenshots and also why I provided the link for if anyone wanted to give it a go. (See what I did there? (; ) haha
ahhh tanks again tanks again... So I can say maybe freeze it with like Titanium Backup or something with no ill effects? ^.^
If you wish.
It doesn't effect much at all if you leave it run.
I use go launcher.
But also have the stock launcher and launcher pro running and my phones still quick and snappy with no lag.
The 01-08 version of this theme borks my device, always ends up leaving me with a massive spam of force closes. When I finally successfully flashed it, my launcher was reset and I had to re-add my widgets and shortcuts, and the notification widgets don't show up properly. The 01-01 version of the theme works fine, but the 01-08 version needs an update badly. Just thought I'd point this out.
Sent from my LG-VM701 Gelato 11-28 ICS Style via Tapatalk
Don't know what to tell ya.
I haven't come across that problem. Nor has anyone have yet to report it to me.
You're the first. Could just have a buggy phone.
Sent from my LG Optimus Slider running Gelato 11 28/ Gingerkernel7.1. Theme:ICS
Maybe it is buggy, I'll try a wipe and clean flash and see if that fixes my issue.
still phresh?
what link do i download, and how? When in recovery the zip doesn't work and sends me to factory reset. After i download your link to my computer, and put it on my phone's SD, i recover the phone and try your ICS software. I am usually good at this stuff, but right now im lost.:confused:
I'm pretty new to installing the ICS theme onto my phone. Can someone provide the ste-by-step process on how to get this theme onto my phone? Thanks for all of the help.
First make a nandroid backup then follow these simple instructions.
1.) Save the ics theme zip somewhere on your sdcard.
2.) Boot into recovery.
3.) Wipe cache and dalvik cache
4.) *Install from zip* choose the theme zip and flash it.
Once complete just reboot as you normally would, if done correctly you won't get fc's upon booting up past the bootlogo.
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
Bump.
For all those looking and asking for my theme files for this. I give you permission to use and distribute AS LONG AS you give proper credits to myself
Sent from my Galaxy Nexus running LiquidSmooth ICS v1.25.
Thoitrangyozu
