There's something wrong with my android battery!
Rhyllei_HG45
3
I am using an android model of huawei Y300-0151 version 4.1.1
I was charging my phone when i noticed that the red light signalling for still charging was on for about two hours. That was when i checked and found out that the battery will only charge for upto 60 %. When I will only let it be, it won't really go up, only that it says charging. After awhile of being stuck to 60 %, the percentage of the battery charged will slowly go down.
Like from 60 %, it will slowly decrease from 59 - up until I will remove the port.
I don't know what is causing this problem.
Please help!
Welcome to the Forums!
It could simply be that the battery is failing. See if you can try another without buying first, in case it isn't the battery, perhaps from a friendly repairer or phone store.
If no go, get back to us and we'll discuss other possibilities.
Thanks ,, I kind of figured it was really the battery's problem.. .. If the battery is really failing, do I have another option on how to solve the battery fail or is buying another battery the only solution?
Jackwills2567
