Thinking about rooting my phone...
There are instructions on how to re root your Inc after manually installing the Nov 17th OTA. I was rooted, manually installed the update, reinstalled clockwork and then reinstaled Superuser. I checked and double checked and I am def rooted. The whole process took about 15 minutes including phone reboots. UnRevoked just released the new version to root after the OTA.
I don't think the new version of unrevoked has been released yet
Sent from my HTC Droid Incredible using Tapatalk
As far as I know, unrevoked has NOT released their update yet. If you have the update, downgrade and then root with Unrevoked. I never applied the update and rooted shortly before the OTA came out.
With Kernels, just be sure that whatever ROM you choose is capable of using that Kernel. I don't like to experiment a whole lot and just stick with the Kernel the ROM builder recommends or builds into the ROM. I know some ROM are not for use with HYDRA kernels, and I don't think you're supposed to use SETPCU with a Hydra kernel. Make sure you read up on what you are mixing, that's all.
Take the time to research downgrading, and then Rooting. I highly recommend it, or just be patient and wait for Unrevoked to release their fix. From what I have read, they have a patch, but it is still being tested before they release it.
cinemacritic
