Thought this was funny and interesting.
I agree that I think that will happen. Although I think a flatter design is not something that can be considered a copied style as windows and BlackBerry also use this style. But I do think Apple needs a taste of their own medicine at every opportunity simply because of their grand sweeping accusations in the past. They have certainly backed off the lawsuit wagon recently.
I'm telling you, Tim cook is a great guy he doesn't wanna get into the law suit mess.
Anyway I can't tell you how much I'm loving Android right now, I love being able to install custom ROMS and custom kernals
I know what jelly bean 4.3(or KLP) can have! a redesign of google maps! if you look at the iOS version of Gmaps it just looks so much cleaner and better.
Same goes for the YouTube app. it looks much better on iOS.
Does that really need to be a part of an Android system/framework update though?
Sent from my DROID BIONIC using Android Central Forums
The YouTube app looks so much better than it did before the last major UI change. I don't know how much better it could get, other than a few performance upgrades.
Sent from my Nexus 4/Nexus 7
Nope. I think they should update them both to look the same.
Look at the iOS version of YouTube. It tells you how many videos one of your particular channel has. It saves me from having to look through my 31 subscriptions separately, it would be easier for me to have numbers.
- - - Updated - - -
- - - Updated - - -
Nope, can be a separate update.
What they need to do is update all the app widgets. Trying to make homescreens with the current widget designs is horrible, just take a look at the difference between the Currents and G+ widgets. They look great on their own, but put them next to each other and they clash so hard.
Look at my post, YouTube can get even better with numbers telling me how many videos my 31 sub subscriptions have pumped out.
I agree. I refuse to use some functional widgets just because they look so ugly. YouTube being the worst.
The YouTube app really needs to fully incorporate the One channel layout.
Sent from my pure Google Nexus 4 using Android Central Forums
Do you know that google themselves said that the iOS versions of their apps are better then the Android counterparts?
They should be they were totally rebuilt. Ours will be getting an update soon I hope. The youtube app is better than it was.
Did you know that Steve wozniak (the cofounder of Apple) said that he wishes that the iPhone had some of the features his android does?
Sent from my XT907 using Android Central Forums
Yes, so? He is right.
- - - Updated - - -
This gives me hope.
gurusdex
