- Oct 1, 2010
- 1,586
- 332
- 83
Hi All:
I've been using 2 non-fast wireless charging stands for a while, then with the S7 Edge, i bought one flat wireless charging stand just to try it out before committing to two of them
well, it IS a little better than the non-fast one, as i think the "sweet spot" of where one needs to place the phone is a bit bigger, so the chances of successful blue light charging is greater.
i'm tempted to not buy a 2nd flat fast wireless charging pad (i need two wireless charging things), but instead, buy one of those that's the new tilted fast wireless charging stands.
may i ask if anyone has any experience comparing the flat fast wireless charging pad versus the tilted fast wireless charging STAND please? is there any performance difference whatsoever?
thanks.
i think there are some differences, as the display on the phone looks different on the product page showing off the tilted fast wireless charging stand, so i thought that the new tilted stand might communicate something different to the phone, and thus, maybe there are some performance differences.
PS: too bad i need the white version of the tilted fast wireless charging stand, and it's not available till at least April 26th
thanks.
