Time not showing correctly!
I have been having the same problem as everyone else. HTC EVO about 10 minutes ahead. I turned off automatic setting and turned it back on and it reset to the correct time. We will see if it lasts.
I just tried this and my phone reverted to the correct time. I guess it's similar to the location bug where you could be in CT but your phone thinks you're in Russia! :)
Wasn't sure what automatic setting was refered to but turning the Evo off then on seemed to fix it. Took a minute or so after it rebooted....
It hasn't reoccured for me yet but all I did was turn on and off airplane mode. This was also happening on my fiance's Evo and it also hasn't reoccured.
Sent from my umm.. phone
Don't know when this thread was started, but mine was 10 minutes fast this morning as well. My alarm went off at 7:50 and I said "WTF?". It showed 8am...I also did the trick of turning auto update on and off. It hasn't happened since, but I will keep my eyes open...
Maybe just killing the radio is enough. When it comes back on it re-establishes it's connection and fixes itself. All I did was un-check then re-check Automatic under Date and Time. If it screws up again I'll try turning off the radio.
5 hours later and my clock is still correct so this seems to have worked.
I haven't had any other problems with the clock since I posted this morning. I also turned off automatic/network time when I noticed it was wrong, then switched it right back on. It corrected itself right away, and, as I said, I haven't had any problems since. *fingers crossed*
At least it was 10 minutes fast and not slow.
ojged4iug2eiwaopnbh
