Tips for my Nexus 5
  • Start date Start date
A
AC Question
Hey guys so my nexus 5 is having battery problems with wrong time for percentage and 1% drain every minute. I thought it was snapchats fault but maybe that isnt it. I did tend to spin my phone on the table so would that be it?
Anyways my options are to either fix the battery, sell phone as is(how much do u guys think), or downgrade to lollipop(i tried this but the fastboot flash wouldnt work and im having this error: is not recognized as an internal or external command).
🙋I'm using a Nexus 5 right now, and I certainly wouldn't spin it, or any other phone if it comes to that. It was and remains a superb device, easily worth fixing in the event of trouble.
Unless you're confident that the battery is failing, do some deeper diagnosing to find what's causing the trouble in your case. If it is the battery, that's easily replaced. Make sure you get a good one.
https://forums.androidcentral.com/showthread.php?t=409154
Ok well i did notice the battery kinda sticks up unless its suppose to do that? I even did a factory reset and that didnt help. I guess a new battery is the solution and thanks for your help.
lilyo7788
