Top half of screen goes crazy
Thanks a bunch! This was bugging the crap out of me. I also removed Clean Master and now the problem is gone. BTW, Flappy Bird was the app that it almost always affected.
I had the problem myself,
Then it was completely solved by doing the following:
Go to Settings > Developer options
Scroll down until you find an option which says:
"Disable HW overlays"
Activate that option( place the tick ) and the problem will be solved.
P.S.: if you face the problem again after rebooting your device for any reason, repeat the same steps.
My g pro was rooted and the same problem happens today.
In Go locker and some other apps.. :)
But the Hw option thing works for me.
All, I also had same problem in my e988. I just uninstalled the clean Master app. Then the problem disappeared!
Thanks to all!
thanks for the info im going back to E98010K and root because there doesnt seem to be any good reason to update to E98010P.
cinemacritic
