Total Booster: Boost RAM, Battery, Network & Clean Phone
Alien IOVA
Total Booster, The No.1 premium booster app in Android.
Boost everything in Android. A must have for every Android device, Speeds up your device and save you time and money.
A very beautiful functional UI, inspired from Win8 tiles design.
Download: https://forums.androidcentral.com/e...com.alieniovaapps.totalbooster&token=nDzEFwAf
★Features:
RAM Booster:
☆ 1 Tap RAM Booster.
☆ Home screen Booster Widget.
☆ Automatically Boost RAM. [PRO]
☆ Boost when RAM is 70%, 80% or 90% used.
☆ Boost in time periods (5 mins, 15 mins, 30 mins, 1 hr, 2 hrs, 3 hrs, 6 hrs, 12 hrs, 18 hrs, 1 day, 2 days)
☆ CPU usage analysis and graph.
☆ Clean while boosting.
☆ Full Memory stats.
☆ Fine, Normal, Strong and Extreme boosts.
☆ Notifications of boost.
Memory Cleaner:
☆ 1Click Memory Cleaner.
☆ Memory Cleaner Home Screen Widget.
☆ Auto Memory Cleaner. [PRO]
☆ Automatically clean device in intervals. [Available intervals: 1 hr, 2 hrs, 3 hrs, 6 hrs, 12 hrs, 18 hrs, 1 day, 2 days, 3 days, 4 days, 1 week, 2 weeks] [PRO]
☆ Percentage of Internal and External Memory usage stats.
☆ All App's Cache cleaner.
☆ Browser History Cleaner.
☆ Gmail Search History Cleaner.
☆ Google Maps Search History Cleaner.
☆ Browser Cache Cleaner.
☆ Google Play Store Search History Cleaner.
☆ Clipboard Cleaner.
☆ YouTube, Google Search and Talk History Cleaner(Manual Clean)
Battery Saver:
☆ 2X Battery Saver.
☆ Complete Battery Info.
☆ Logging of performed actions.
☆ Highly configurable settings.
☆ Battery Alarm:
☆ Full battery Alarm : Vibrate and notify when battery is fully charged.
☆ Low Battery Alarm : Vibrate and notify when battery is low. Options available to set your preferred low level (5%, 10%, 15%, 20%, 25%).
Network Resetter:
☆ Resets network connection and solves most of the network issues.
☆ Refreshed signal is found to have more strength in most cases.
☆ Can reconnect quickly to lost data connection.
☆ 8 out of 10 usage of this app increased the connection quality. This means increased internet speed and good quality.
☆ Sets 4G if found in the area. the set priority order is 4G-3G-2G.
☆ Saves Battery life with a more stable signal.
Alien IOVA.
Apps like this reflect a complete lack of understanding of how Android (and Unix / Linux in general) manage memory.....
Wow, what a brilliantly pointless way of solving a problem that doesn't exist.
If anyone is thinking of getting this, don't, just don't. It's pointless garbage that preys on people's ignorance.
Just look after your phone, uninstall apps you don't use or that misbehave, don't install **** from naughty websites and you'll be fine.
I am far from a savy phone guy and I realized this on my own. Most of these apps make little to no difference. Same with battery saving apps.
legitimate battery saving apps can help. I use juicedefender and get a bit extra, as it turns off Internet on a schedule which does actually help.
My phones already do that on their own. Juicedefender is an incredibly juice sucking app on it's own.
gulkhile
