Touchwiz or Launcher
I go back and forth. Currently using tw with a Christmas theme.
Sent from my SM-T800 using Android Central
Stock. Before switching to the note 5 from note 4 i only used nova with custom icons and keyboards. Now i just choose a theme and maybe use line to change the icons. The wallpaper apps to pic out a few and im done.
We need more themes tho to choose from
Thanks for your post, had no idea about the Line app....just downloaded and changed the icons for a theme store theme that I liked all except some of the icons didn't match the theme....they do now
Nova is the best android launcher, hands down. Been using it for a few years now. Plus, you can't go wrong with the 99cent deal!!
I hate Touchwiz!!! It put big icons on my window and removed a lot of icons that I wanted, then it puts all these plus signs on my window, it completely hides my wallpaper which is a picture of a deceased loved one. How do I remove touchwiz????? It's gotta go!!
Sounds like you have Easy Mode turned on. Turn that off and you'll have a normal screen to work with.
I was using TouchWiz since I got the Note 4 but could not pass up the opportunity for Nova Prime at 99 cents, liking it a lot so far.
Current look
Previous
Had another look but it looks like i deleted it. Sucks but ill prolly go back to it after the holidays. Lol
Was using TW until a week ago. My TW didnt give any problems and it looked great but tried out nova prime as many say it's good. And it really is. Gestures coupled with icon packs really look and feel great. Love that you can represent folders by a single app icon. Only issue is that some widgets appear bigger than they do on TW and they don't look as nice (my calendar widget, smart manager). Any pro novas know a fix for this?
Currently rocking...
uploadfromtaptalk1450076559348.jpguploadfromtaptalk1450076575331.jpguploadfromtaptalk1450076585534.jpg
Just started using Nova. My only complaint is that you can't custom sort apps in the app drawer. Am I missing something?
Here is the screen shot of the app drawer. Only option is alphabetical.
Also, if I download a new app, it is like 3 or 4 clicks to add it to a folder.
For both of these, it is a simple drag and drop on touch wiz.
Didn't want to start a new thread, but I have a launcher question.<br />
I frequently switch between Nova and Action Launcher 3, but are they running at the same time? Do I need to stop one when using the other?
wobblefix
