Triangle Away for the Verizon Note 2?
RLLangley
127
Anyone know if Triangle Away works for the Verizon Note 2 or if there is a way to reset the counter yet?
Thanks
Thanks
It does not work. I heard flashing the 100% stock rom may reset it but I forgot to check last time I flashed stock. Ill try it tomorrow night as I won't be near a computer till then and let you know
From my Galaxy Note 2 via Tapatalk
Is it annoying that I answer so many questions in this section lol
Not really. I pretty much have come to expect it. Seems the past few post is me just asking questions and you answering. I also wanted to post my questions as others start doing some of this they question may already be answered here.
Well looks like Triangle Away has been updated to support our Note 2
Samsung Galaxy Note 2:
- SCH-I605 Verizon ** (unlocked bootloader only)
Gave it a go and worked perfect. Cleared up my phone just fine. :D
Now is this a pretty safe and easy app to use to reset my count? Never used it but would like to reset my mistake :D
I guess you would have to flash stock rooted package with Odin then use triangle away, then unroot and leave the bootloader unlocked. Because if you were to flash just the locked bootloader after using triangle away it should trip the counter again. I guess ill have to test this out or find someone who has. Thanks for the heads up
cinemacritic
