Trusted Places
I've set it up for work and home. It works great, I've only gas a problem once with the gps accuracy, but opening maps fixed that. It works for me on gps battery saving. I took off work as a trusted place because I almost forgot my phone in the bathroom.
When I selected Home and activated Trusted Places, I saw it had my home address that I had typed in before. There is a error on Google Maps with my home address that is off by about 50 meters on someone else house when I enter my address into Google Maps. I wonder if Trusted Places uses the home address or the GPS location it finds when you set it up?
If it is just GPS they use you may want to try walking a 10 or 30 feet from you home (try each side of the home separately) and reset it as your home on Trusted Places. Most GPS inside a home have about 30 to 100 feet accuracy since it doesn't have a clear signal through your roof to the GPS satellites.
I will definitely try that!
OK how do I reset my Trusted Places? I can't find it. I can't simply add another as it tells me "this is already a trusted place". Well if it's a trusted place already why doesn't it work lol....
pmm09
