TSM Pool Party Volume issue
sushiguy732
1,351
46
When I make a call, either on speaker or not, the volume is REAL LOUD. Can anyone help me with a way to fix this? I think it has to do with the init.d file but I am not sure.
I know I can manually turn down the volume but I thought there is a technical workaround.
If anyone knows I'd appreciate the help.
had the same issue on CyanogenMod 7.1, unfortunately when I turned it down it would go to really low... if back up, then loud and distorted. I'm back to stock 2.2.2 for now. I think I have come across that changing kernels can make a difference though. Sorry, not too detailed.
I have been able to answer the phone or start the call.. dial the volume down and/or back up to meet my needs. I am aware that this is a persistent issue with CM7.x - It may take some time to correct.
I thought there was a configuration file that could be tweaked... Is this not the case?
The file you are referring to won't work with jt's kernel. I think it will work with Glitch tho.
Sent from my SCH-I500 using Tapatalk
zolepso1
