- Oct 26, 2012
- 48
- 0
- 6
Please tell me there is a way to turn off the sound the phone makes when it is plugged into a charger? I am not rooted and would prefer to stay that way for simplicity sake. This sound is bugging the crap out of me.
What you need to do is create a profile that has all sounds turned off. Call it "Silent" of something like that. Then create a rule with a condition for Battery, plugged into any charger, and an action to activate profile "Silent."
You will probably also want to create a default profile that has sounds turned on. When you plug the phone into a charger, SP will recognize that event, and start the "Silent" profile. When you unplug it, the phone will revert to the default profile.
What is the easily way to root? I mean as basic and non-time consuming as possible.
Wouldn't this make all notifications "silent" when the phone is plugged in then?
- - - Updated - - -
Ok I will check it out at home.... Is it easy? I'm pretty tech savvy but I don't like taking risks
Sent from my Galaxy using Tapatalk
Can you please post instructions on just how to cancel the various noises. My phone is rooted .
