Turn on wifi automatically not working with Android 10
korab84
295
Ever since I upgraded my phone to Android 10 the "turn on wifi automatically" feature doesn't connect automatically when I'm near a known wifi connection (home or work); I have to manually turn on wifi (I know it's hard to do) and this feature used to work fine on Android 9.
Connect to a WiFi connection? Or turn it on from an off state? (I don't turn it off, It just disconnects and stops using much battery. I don't think the radio can turn itself on if you have it turned off.)
Tu turn on from an off state automatically...there's an option for this but my Pixel 3a won't activate it when I get home or at work (be both saved networks)
gulkhile
