- Apr 23, 2011
- 30,108
- 207
- 63
Well, i'm having the battery drain idle issue that some others are having. About 80-270ma (avg maybe 140ma) at idle without running anything, even after restart. When i first got the phone, it would typically idle around 40-44ma. with the music (local of course, not streaming radio), i noticed the idle to be 56-60ma. Music does use some juice, but i figure, it's better to run 60ma than 140ma. When i put the music player on pause, it will go back to using the 140ma again. I realize how much power is used can vary depending on apps running so you may get different numbers,, but either way, the music seems to really cut down on the power consumption. Anyone else notice the same thing?
btw, i tried a factory reset, but the high power drain at idle persisted.
btw, i'm using Battery Monitor Widget, but there are other widgets that provide the same info.
