[Tutorial] Data Toggle ***Battery Saver***
Bandage
20
Ok so those of you who own the Photon have probably noticed Motorola buried the Data Toggle option deep in menus we're not used to finding them in. None of the current Toggle / Widget apps support access to this menu with a single click.
EarlyMon (Android Forums) pointed out a free Toggle App, that with some exploration and trial I was able to come up with a work-around that allows a single press Data Toggle.
Here's a quick tutorial:
1. Download Widgetsoid2.x and install.
2. Long-press on Home Screen, and select "Widgets"
3. Scroll down to Widgetsoid Switcher 1x1
4. 1st option on the toolbar down on the bottom is "Network" select that.
5. Select "Mobile Data"
6. Next go to Theme...and customize the look you want for the toggle.
7. Select Apply on lower menu bar
8. A menu will pop up asking if you want to "Edit Global Preferences"...Choose Yes
9. The first Tab from top is "Data Toggle Mode"
10. Select "Root Toggle"
11. Press your BACK key...and it will return you to your Home Screen.
Done... There's your Data Toggle!
Reactions: ScandaLeX
I did it the first time and it worked, not I am on day 3 and it doesn't work at all even after uninstalling and installing
Just got my photon & trying to learn lots of stuff all at once. Curious what help this Data Toggle really is - when you use it and why?
i have data enabler on my photon works like a charm and all you have to do is download it from the market super easy.
kiki2025
