Two Bluetooth Speaker Connection Issues
Zgwforum
5
I am trying to connect 2 Bluetooth speakers to my S25+(Android v16, UI v8).
When I am able to connect 2 bluetooth speakers to my S25+, about 3 seconds after both speakers are playing, one of the speakers drops out of playing. The 2nd speaker continues to play.
When I reconnect, and get both speakers to play again, the 2nd speaker will drop out and the 1st speaker will continue to play.
Thank you for any help.
I've heard One UI 8 having this bug
But things to try
Settings → Connections → Bluetooth
Tap the next to Speaker 1
Turn OFF “LE Audio”
Repeat for Speaker 2
Reboot phone
Re-pair both speakers (delete them first, then pair again)
Turn on Samsung Dual Audio (don’t rely on “just pairing twice”)
Bluetooth → Advanced
Enable Dual Audio
Connect Speaker A
Connect Speaker B
Start audio after both are connected
Start playback after both are connected, not before.
Enable Developer Options
Settings → Developer Options
Scroll to Bluetooth Audio Codec
Set SBC
Set:
Sample rate: 44.1 kHz
Bits per sample: 16-bit
Reconnect speakers
This reduces bandwidth stress and keeps both streams alive
Also go to settings>apps>Bluetooth>battery set to unrestricted same as media app your using
oguk
