TWRP Loop after factory reset (Cyanogenmod 12.1)
Same trouble here.... Cyanogenmod 12.1 + factory reset= teamwin-loop.
You can't recovery boot or download boot?
Try hardware download mode with USB Jig plug. you can buy it at amazon or ebay, or you can do it your own.
It's really simply. Believe it works!
Link: eduwebcell.blogspot.com.br/2015/09/como-fazer-um-jig-usb.html (brazilian-Portuguese language. you can translate it.)
Good lucky
No need to enter the download mode, just leave the teamwin screen loop and make the commands that I quoted above.
I tried this same solution I have seen on another blog. But in my case it did not work .. The only solution that worked for me, is JIG PLUG. But thanks.
Hi Thankyou so much. The first command worked for me. But the second one did not worked. But thankfully I was able to get into the TEAMWIN menu n I backed up my BOOT and SYSTEM. then I tried bootloader, and I went to HBOOT n REBOOT , it took me to the black screen again.
Can you give me any solution?
I\m having the same problem.
error: no device/emulators found
I've the latest samsung diver for mobile phones.
In Odin the same. The device is not recognized even with a memory card.
What else can I do??
This is the only solution for me.
I flashed cwm over Twrp and its ok.
None of other suggestions work. Thanks mate
Hi, please I have tried flashing cwm, over twrp and it still didn't enter recovery mode, please any other solution?
Thanks man!!!
Where are do you live? I want to by you a beer ;)
I spent few weeks to find this fix
I had a really similar problem with my Galaxy S4 Mini [GT-I9192] and was looking at this thread for help. I have cyanogenmod and after factory reset my phone was stuck in a boot loop I could not do anything but launch it in download mode, I accidentaly found a video on youtube with a guy that had the same problem as mine, and in the comments one guy showed this solution:
-> press Power+Home until the device powers off
-> when turned off press Power+Home+Volume down until device powers on
-> keep holding Home+Volume Down until the download mode warning appears
-> cancel with Volume Down to reboot into Android
It worked for me so i figured out I should post here :)
No need to enter the download mode, just leave the teamwin screen loop!
I had the same problem, here is a help
1. Download the program "Minimal ADB and Fastboot"
2. Connect your phone to your computer
3. Open the ADB and Fastboot Minimal
4. Type in cmd in the program will open: "adb reboot recovery" without quotes and enter.
5. Type in cmd in the progam will open: "adb reboot bootloader" without quotes and enter.
6. Wait, your phone will reboot and see if it worked.
I hope this helps
Hi, I'm having the same problem. I followed your instructions, and it seems to do something. Instead of opening teamwin it shows the Fastboot logo. But that's all it does, when I try to give it other commands, it says "wating for device". It never goes out of fastboot mode unless I power off. When I turn back on, my device reverts back to the original problem.
PLEASE help me out here. to help fix this ill specify EVERYthing within my ability.
First off, none of these solutions have worked for me... and im on a kindle fire.
Second: my situation. I reset to factory after installing cyoganmod/whatever its called and got into a boot loop when i type adb reboot recovery or just flat out boot the kindle. I cant launch download mode, because all I have is power volume up-down, and i think the combo requires the home button. I have tried power+up/power+down on boot but it just shuts off as soon as the fire in "kindle fire" turns blue. When I type adb reboot bootloader it gets stuck on the Fastboot logo screen, and typing further commands just hangs at "waiting for device"
EDIT: and i should mention: when i get stuck on fastboot the kindle isnt recognized properly by windows like it does when its stuck on twrp
I hope this helps
When I connect my bootlooped device Windows doesn't recognise it, no sound, and it doesn't even appear in the device manager. The device only turns on as if it was given power but I really don't know. :mad:
it worked for me...but no need of executing those commands...just flash cmw recovery mode over twrp recovery....you can watch a tutorial on youtube "how to install cmw recover using odin":)
I fixed my TWRP bootloup on my samsung s3 mini, all I did was download a file called
i8190 stock - recovery.tar.md5 then open Odin clicked pda and selected file from desktop put phone in downloadmode connected it press start on Odin and boom! worked a treat :-)
emilieysins
