UG802 Mini PC
Hello guys!
I recently bought UG802 but the stick is unable to find any wifi network at all! I opened the case to see if the wifi antenna is properly connected, and found no problem at all. UG802 still can not find the router. Is there a solution for this?
Thanks.
My personal experience , I've worked the internet with a UG 802 it is dependable so long as the permission to allow unknown sources box remains unchecked ie locked as a stand alone devise.It took a few weeks of reviewing this to be convinced it is reliable and will reply all media precisely A''AS PROVIDED" quality depends
on this factor more than all else with wifi connect,it can be commanded from line it is likely the production of the item in regards to manufacture overstated otherwise.
yeah well in reply to a question of whats new about the 802 not much from what I'ver read as I'd expect it is a copy of a wireless communicans devise dates well before the public afford of internet communication vend.....
Sure follow the poor written instuctions it came with . Hey no joke follow the prompts with the instruct the once on line erace the settings back to factory three or four times ....yeah for practice.
Does anyone know much about the new UG802 Mini PC? Is it actually new? Is it considered an upgrade to the MK802? The only difference I see is that the UG802 is dual core vs the MK802 which is single core.
The UG007 and UG007 II MiniPC devices are the Android 4.1.1 (Jelly Bean) successors to the UG802. For more than you might want to know about the UG007 and other Android 4.1+ MiniPCs, see my lengthy First Look at the CozySwan UG007 and Other Android 4.1+ MiniPC Devices blog post.
Cheers,
--rj
Ashok Dharshan
