UK Unlocked Note 10/10+ June Update!
I hope so but yeh really interested in any new features coming in One UI 2.5 as you mentioned ??????
UI 2.1 was an update that actually felt like an upgrade for a change and rumours pointing at 2.5 being even more so...
You guys Lucky , easy to root:)
I'm not even going to bother with the 10+. Will be the first Note I've not within a couple of days and have no intention of doing so.
I'll miss my circle battery indicator and a couple of other things but on the up side I can use google pay now.
From reading it's also much easier to **** up the rooting, completely bricking or just tripping the tamper flag.
Yeah , today with Nova launcher,Good Lock, Package Disabler Pro ...no need to root anymore
Still trying to get a universal black theme rather than the night mode grey theme (Substratum was another root ap on the 8).
Not seen Package Disabler. What do you roccomend that for?
Have Nova. Using QuickStar on Good Lock. Experimented with others but couldn't find much else I wanted. Would be good to hear what other enhancements others have found. Maybe in another thread so we don't hijack this one about the update (https://forums.androidcentral.com/s...ote10-no-longer-require-root.html#post6804020).
Package Disabler can disable system apps that you normally couldn't without root , very good tool to have .
I just pretend Bixby is not there on the Ultra.....maybe easier because no button
It's not just bixby , it's other system apps , you can lean out your apps that normal couldn't unless rooted . I like a little leaner system :)
I'd have a hard time finding them now. I just silenced the notifications so the previous is helpful to actually turn them off for those extra couple of minutes battery a day. Will torobably leave bixby as an app as I am cuttently comparing it to Google for text recognition fro image and also turning it off may interfere with the smart select text conversion.
Yeah it's what you choose , I have some experience with Samsung so I know what to go to first and disable.
I'm pretty familiar as well, or was, but there seem to be a shed load of new services that have come in since Note8/Adndroid8 (locked static for updates for a year)
I'm pretty familiar as well but there seem to be a shed load of ne services that have come in since Note8/Adndroid8
Yes there is , just stick with the ones you know leave others until you research them , usually has a link in PDP what it does .
My update just come through and pretty big at just over 800mb 😊
reblkari666
