Un-Brick method for SOME forms of brick
ok i could really use a smart guys help here. i am not new to the rooting game, but i am jus now finding out about E Mode. So i put my optimus s in e mode for the 1st time in a year that i had this phone. i was able to use the lg mobile software update while in e mode my phone was recognized then it when to crap at 30%. i unplugged my cable then reinserted it and now my phone powers on and off but i clicked restart and still nothing stuck at 30 %. am i doing something wrong?
problem two. while using kp500-utils-en.exe i pressed j and nothing happened i also have the other file i needed to use with this program.
im jus lost here trying to learn as well if you have any input thoughts comments or concerns theories helpful advice email me at bjwoods167@yahoo.com or facebook me Bruce Woods Jr or by that email on FB as well. o yea need help with adb cmds two i look up threads all the time and i know you guys are smarter than me at this so i would greatly appropriate the help
Does anyone have an updated location for the kp500 utils v0.4.2 file and the VC cab? Tried looking for them on other torrent sites and couldn't find anything. Thanks.
i used this method to unbrick my bad boot flash.
Normal mode just had LG(bootloop)
recovery mode was a black screen(recovery was working before the flash)
my Emergency mode kept resetting atrandom intervals(usually between10-20 seconds)
Had to do this 20-30 times then did the battery trick.
Yay. unbricked
Okay guys, I used this method for my bricked Optimus V. I was unable to get passed the LG boot up screen and was unable to use any key presses to get into system recovery or anything like that. So I tried this and it worked perfectly. BUT, now my Virgin Mobile Optimus is now SPRINT. I'm glad I was able to unbrick it, but now how do I change it back to Virgin Mobile? I've tried using most cab files out there but they don't seem to be working. Can someone please help me. Th cab's I used are VM670ZV4_13.S4_13.P61007.cab(this is missing a dll file) and VM670ZV5_07.cab. The sprint one I used came from Zefie..
Index of /zefie/files/cell/LGLS670/roms/LGUpdater/cab - Persona Files
LS670ZVD_12.SD_12.P60675.cab
What can I do? Please help me
These are the steps I took..
1) Disconnect phone from PC, power, and battery
2) Get kp500 utils v0.4.2 (MEGAUPLOAD - The leading online storage and file delivery service)
3) Get cab http://files.persona.cc/zefie/files/cell/LGLS670/roms/LGUpdater/cab/]Index of /zefie/files/cell/LGLS670/roms/LGUpdater/cab - Persona Files
4) Save cab as C:\LS670ZVC_11.SC_11.P60674.cab
5) Run KP500-Utils-EN.exe, need only that exe and all the DLLs from
zip in step 2
6) Press J
7) Model: LS670
8) Cab: C:\LS670ZVC_11.SC_11.P60674.cab (u can paste this into cmd
prompt by clicking icon on the top left, edit, paste)
9) Version: LS670ZVC
10) When LG fails to find your phone, launch "emergency mode". When
E-mode is active and the drivers are installed, press the "restart"
button on the LG update
11) The LG update will fail and say it lost connection with your
phone. The phone will say do not remove power. But guess what.. you
have to. So do so. Then plug it back in without any button voodoo and
it should go back to the updating warning.( if there is a % on the screen do not pull the cable)
12) Press restart on LG Updater and enjoy.
This is the Log File from trying to use the above VM cab files..
05:11:09 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
05:11:09 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
05:11:09 : Start Date : 2012-03-26 05:11:09
05:11:09 : -------- Buyer Test mode ---------
05:11:09 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
05:11:09 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
05:11:09 : *****CheckOS Start********
05:11:09 : Microsoft_Windows_Vista Professional_
05:11:09 : *****CheckPCSyncPrograms Start*****
05:11:10 : PCSyncPrograms Not Found
05:11:10 : SetEmerModeAT()
05:11:10 : _IsConnectedPhone Call
05:11:15 : _IsConnectedPhone(1)
05:11:15 : 0 - NotConnected.
05:11:15 : 1 - Normal connect success
05:11:15 : 2 - Emergency connect success
05:11:19 : Checking the connection with the cell phone...
05:11:19 : dwWaitResetTime(40000 ms)
05:11:20 : Phone Mode(1)
05:11:20 : *****GetPhoneType Start*****
05:11:23 : Phone Type : CDMA
05:11:23 : *****Start GetPreviousStep*****
05:11:23 : _GetPreviousStep(dwStep:0xffff)
05:11:23 : _SetPhoneNumber retval=1
05:11:23 : *****GetPhoneModel Start*****
05:11:25 : *****GetPhoneBinaryVersion Start*****
05:11:25 : Phone Bin Version : LS670ZVD_12
05:11:25 : *****Get ESN / IMEI / MEID Start*****
05:11:36 : ESN/IMEI/MEID : 80F5C8B2
05:11:36 : *****GetPhoneNumber Start*****
05:11:39 : Phone Number : 80F5C8B2
05:11:39 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 80F5C8B2, Model :
05:11:39 : *******CheckBinVersion***************
05:11:39 : New Bin Version(VM670ZV4_13), Current Ver(LS670ZVD_12)
05:11:42 : _GetAuthMark : wAuthMark(23596)
05:11:42 : Wait 3Sec
05:11:47 : _SetAuthMark Ok : wAuthMark(23596), PhoneMode(1)
05:11:47 : *****Start _GetBatteryLevel*****
05:11:50 : Battery(5)
05:11:51 : ResetPhone...
05:11:51 : Checking the connection with the cell phone...
05:11:51 : dwWaitResetTime(40000 ms)
05:12:21 : _IsConnectedPhone Call
05:12:27 : _IsConnectedPhone(1)
05:12:27 : 0 - NotConnected.
05:12:27 : 1 - Normal connect success
05:12:27 : 2 - Emergency connect success
05:12:27 : Phone Mode(1)
05:12:27 : m_dwBootWaitTime(35558)
05:12:27 : Checking the connection with the cell phone...
05:12:27 : dwWaitResetTime(30000 ms)
05:12:57 : _IsConnectedPhone Call
05:13:02 : _IsConnectedPhone(1)
05:13:02 : 0 - NotConnected.
05:13:02 : 1 - Normal connect success
05:13:02 : 2 - Emergency connect success
05:13:02 : Phone Mode(1)
05:13:02 : Call _ModeOffline()
05:13:03 : *****CheckPCSyncPrograms Start*****
05:13:04 : PCSyncPrograms Not Found
05:13:05 : CLGMobileHttp Class ?Ҹ????.
05:13:05 : CLGMobileHttp Class ?Ҹ?...
05:13:05 : ****************CheckAndDownload********************
05:13:05 : ******Extract Start C:\VM670ZV4_13.S4_13.P61007.CAB*****
05:13:05 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
05:13:05 : ExtractInfo Error(0)
05:13:05 : Extract cab file error.
05:13:05 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
05:13:05 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
05:13:05 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
05:13:05 : Page_Error ?κ??Դϴ?
05:13:05 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
05:13:09 : =======Cancel button click : m_nStep(5)
Tried this an the phone goes to boot up but won't get past the Sprint ID setup screen. What do I need to do to get a ROM on here now. I can't get into usb debugging.
Thanks.
FIRST READ ALL OF THIS POST
You will need to go into EMERGENCY MODE(Will be called E-mode in this guide)
If you have a extra person around ask them to help you,use you toes if you have to,or buy a monkey.lol
*To enter E-mode*
You will hold the following buttons
hold volume down+camera+search(not the side one)then while plugging into pc press and hold power. You should go into a screen that has EMERGENCY MODE displayed in red letters.
We are not responsible for your device,don't blame us if your monkey stops eating bannans,your car gets a flat tire,if your sdcard grows legs and walks out your phone.We tried to test this as muchs possible but freak things happen and we can't be at fault.:D
3) Get VC cab (http://files.mysticmidnight.net/zef...PST Recovery/cab/LS670ZVC_11.SC_11.P60674.cab)
zip in step 2
6) Press J
7) Model: LS670
Once everything is done go back up one post and hit that thanks button for zefie cause without him this wouldn't of been possible. Plus he tested this several times so thank you again zefie.;) Thanks goes to our phones we bricked that lead us to this.lol
My phone has no screen working.. Just blank.. The backlight comes on, and the buttons have light. But it has no light.. Can't tell if it goes into Emergncy mode or not :\
I flashed the wrong kdz now this whole thing got even worse :((
Any advice??
Any advice??
What recovery do you have installed and where did you get it? Have you tried any of the screencast software yet?
I've bricked my LG Optimus S twise! (Like a boss) The first time this method worked. But thiss time im getting to 95% in the updae and my phone will reboot and itll make it to 99% complete then fail.:'( Any fixes to my problem? I've tried this on My Windows XP Professional Pc , My Vista PC, And my Windows 7 Ultimate Pc and all have the same result. Any help? Im still new to Android and dont know anything! And if it helps the last rom I was running was Cyanogen Mod 9 And my last recovery was ClockWorkMode 5.0.0.7 Optimus C
There is the problem. Clockworkmod isn't compatible with the OptiS
Sent from my SPH-D710 using Android Central Forums
That's not entirely true. The problem is that he is using a version for an Optimus C, which is not an Optimus S; THAT instance of CWM is not compatible. XIonia or an earlier version of Drew's CWMT are examples of ported CWM that does work. The poster needs to ensure compatibility of the software he is installing, instead of assuming that it's close enough.
The version I used to use was Clockwork Mod for LG Optimus V and it worked perfectly. But after I got this new one Optimus V recovery wouldnt boot so I instead use Optimus C and controled it via ROM Manager. But to the point I cannot use my Optimus C recovery although I can boot in to it fine. There is no selection key. It is appreciated if anyone could teach me if it is posible to get standard flash by using E-MODE? All replied are appeciated Thank yall for your help.
I have tried every suggestion but i still get an error. Update gets stuck at 4% then tells me to reconnect phone.
Log:
15:27:20 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
15:27:20 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
15:27:20 : Start Date : 2013-08-06 15:27:20
15:27:20 : -------- Buyer Test mode ---------
15:27:20 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
15:27:20 : RemoveDirectory1 Error(5):C:\ProgramData\LGMOBILEAX\Phone
15:27:20 : *****CheckOS Start********
15:27:20 : Microsoft_Windows_Vista Professional_
15:27:20 : *****CheckPCSyncPrograms Start*****
15:27:20 : PCSyncPrograms Not Found
15:27:20 : SetEmerModeAT()
15:27:20 : _IsConnectedPhone Call
15:27:20 : _IsConnectedPhone(0)
15:27:20 : 0 - NotConnected.
15:27:20 : 1 - Normal connect success
15:27:20 : 2 - Emergency connect success
15:27:27 : Verifying phone connection...
15:27:27 : dwWaitResetTime(40000 ms)
15:27:28 : _IsConnectedPhone Call
15:27:35 : _IsConnectedPhone(2)
15:27:35 : 0 - NotConnected.
15:27:35 : 1 - Normal connect success
15:27:35 : 2 - Emergency connect success
15:27:35 : Phone Mode(2)
15:27:35 : *****GetPhoneType Start*****
15:27:38 : Phone Type : CDMA
15:27:38 : *****Start GetPreviousStep*****
15:27:38 : _GetPreviousStep(dwStep:0x5)
15:27:38 : *****GetPhoneBinaryVersion Start*****
15:27:38 : CSE mode -> Version Replace
15:27:38 : *****Get ESN / IMEI / MEID Start*****
15:27:50 : *****GetPhoneNumber Start*****
15:27:52 : Phone Number : 00000000000
15:27:53 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 00000000000, Model :
15:27:55 : _GetAuthMark : wAuthMark(5774)
15:27:55 : Wait 3Sec
15:28:01 : _SetAuthMark Ok : wAuthMark(5774), PhoneMode(2)
15:28:01 : *****CheckPCSyncPrograms Start*****
15:28:01 : PCSyncPrograms Not Found
15:28:02 : CLGMobileHttp Class ?Ҹ????.
15:28:02 : CLGMobileHttp Class ?Ҹ?...
15:28:02 : ****************CheckAndDownload********************
15:28:02 : ******Extract Start LS670ZV9.cab*****
15:28:02 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
15:28:12 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb\n
15:28:12 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb)
15:28:12 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll\n
15:28:12 : Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll)
15:28:12 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdh\n
15:28:12 : NNNNN WDB FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
15:28:12 : NNNNN Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
15:28:12 : Extract End LS670ZV9.cab
15:28:12 : *****WorkModelDLL Start*****
15:28:13 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
15:28:13 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
15:28:13 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
15:28:13 : m_nPhoneMode(2)
15:28:13 : Phone mode 1 = Normal
15:28:13 : Phone mode 2 = Emergency
15:28:13 : Phone mode 4 = CSE
15:28:13 : _DetachDLL Call
15:28:13 : _DetachDLL Call End
15:28:13 : Call fn_StartUpgrade
15:28:13 : ### Start Upgrade - CDMA ###
15:28:13 : ********* CDMA Model.dll input Parameter *************
15:28:13 : MODEL_EVENT : 32769
15:28:13 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
15:28:13 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
15:28:13 : BootWaitTime : 49500
15:28:13 : UsbHighSpeed : FALSE
15:28:13 : PhoneMode : 2
15:28:13 : NewPhoneBinVersion : LS670ZV9_20
15:28:13 : ClearSI : FALSE
15:28:13 : AuthMark : 5774
15:28:13 : ********* CDMA Model.dll input Parameter End*************
15:28:15 : wParam : 20, lParam = 570
15:28:15 : MODEL DLL Event : (20, 570)
15:28:15 : Model Dll Msg Not Found(20, 570)
15:28:37 : wParam : 100, lParam = 83
15:28:37 : MODEL DLL Event : (100, 83)
15:28:37 : CleanModelDll() : Free Model.dll
15:28:37 : _DetachDLL Call
15:28:37 : _DetachDLL Call End
15:28:37 : FreeLibrary Call
15:28:39 : FreeLibrary Call End
15:28:40 : wParam : 20, lParam = 0
15:28:40 : MODEL DLL Event : (20, 0)
15:28:40 : Model Dll Msg Not Found(20, 0)
15:28:40 : Page_Error ?κ??Դϴ?
15:28:40 : ????? Retry ?κ??Դϴ?
15:29:01 : Call Retry Thread
15:29:01 : Verifying phone connection...
15:29:01 : dwWaitResetTime(40000 ms)
15:29:05 : _IsConnectedPhone Call
15:29:12 : _IsConnectedPhone(2)
15:29:12 : 0 - NotConnected.
15:29:12 : 1 - Normal connect success
15:29:12 : 2 - Emergency connect success
15:29:12 : Phone Mode(2)
15:29:12 : *****WorkModelDLL Start*****
15:29:13 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
15:29:13 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
15:29:13 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
15:29:13 : m_nPhoneMode(2)
15:29:13 : Phone mode 1 = Normal
15:29:13 : Phone mode 2 = Emergency
15:29:13 : Phone mode 4 = CSE
15:29:13 : _DetachDLL Call
15:29:13 : _DetachDLL Call End
15:29:13 : Call fn_StartUpgrade
15:29:13 : ### Start Upgrade - CDMA ###
15:29:13 : ********* CDMA Model.dll input Parameter *************
15:29:13 : MODEL_EVENT : 32769
15:29:13 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
15:29:13 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
15:29:13 : BootWaitTime : 74250
15:29:13 : UsbHighSpeed : FALSE
15:29:13 : PhoneMode : 2
15:29:13 : NewPhoneBinVersion : LS670ZV9_20
15:29:13 : ClearSI : FALSE
15:29:13 : AuthMark : 5774
15:29:13 : ********* CDMA Model.dll input Parameter End*************
15:29:14 : wParam : 20, lParam = 570
15:29:14 : MODEL DLL Event : (20, 570)
15:29:14 : Model Dll Msg Not Found(20, 570)
15:29:24 : wParam : 6, lParam = 0
15:29:24 : MODEL DLL Event : (6, 0)
15:29:24 : wParam : 100, lParam = 84
15:29:24 : MODEL DLL Event : (100, 84)
15:29:24 : CleanModelDll() : Free Model.dll
15:29:24 : _DetachDLL Call
15:29:24 : _DetachDLL Call End
15:29:24 : FreeLibrary Call
15:29:26 : FreeLibrary Call End
15:29:27 : wParam : 20, lParam = 0
15:29:27 : MODEL DLL Event : (20, 0)
15:29:28 : Model Dll Msg Not Found(20, 0)
15:29:28 : Page_Error ?κ??Դϴ?
15:29:28 : ????? Retry ?κ??Դϴ?
dumpsterrentals85
