Un-installing android system apss
sinchichiu
4
I just wany to ask if can I un-install those android system apps like google +, messenger+, youtube,​
photo editor, video editor, etc... without having any hardware or device problem? Cause they're just useless to me... I'm am using galaxy tab 2 npt rooted...
Hope anyone can answer my question...
NO! Not with the factory setup!
If you root your Tab you can remove some of these apps. Search for ROOT and you can find some links to replace your stock OS with a modified OS that leaves out these Bloatware Apps
vicinity
