Unfortunately android wear has stopped
Guys I have found a way to fix this issue.I presume you all are getting the message that unfortunately android wear has stopped working.
I fixed this problem by chance as I was messing around with my Moto 360 watch.
Its quite simple, just follow these steps:-
1. press the button on the side till the watch turns off completely. There will be a light dark screen at first which is quite difficult to see(for this go into a dark room or do it at night in absolute darkness) but it will be there so make sure that it is completely off (black screen).
2. once you have shut it off, turn it on again , you should feel a slight vibration when doing that.
3. once it is ON you should see the watch screen , as soon as you see that swipe to the right (you have about 1 second to swipe) and go to settings , the error message will keep on popping up but you can keep on pressing OK on that and you shouldn't have a problem.
4. When you are on the settings , go to unpair with the phone option to reset the watch and reset it. All this while the error message will keep popping up and just keep on pressing on OK and it will be fine.
5. Wait for the message - resetting device to factory settings and follow the steps to setup the watch again and it should work fine.
Doing this will delete any data on the watch and delete the android wear app on your phone and reinstall it as it may be corrupted by a virus.
This method worked for me but I do not know wether it will work for you or not. Either way let me know by contacting me by email at (email address removed by Moderator) .
Mod Note, please do not post your email address on this public forum
Jackwills2567
