Unfortunately, Clock has stopped. How do I fix this after my Lollipop install?
Yes, it finally worked. Thank you so much for posting the solution! I hate how all Samsung does is suggest clear cache and factory reset. Once again, thanks so much. :D
For those who still suffering from this issue:
1.Go to Setting > Date and Time > Date format > Regional
OR
2.The alarm clock's glitch happened when you have your sound volume totally off , so simply turn on your sound volume and its all good.
OMG.... This is unbelievable!! The volume thing worked for me :D Thanks a ton, never thought this would work.
Settings--(MyDevice)--(More)--App Manager--Clock.
Clear Cache, Clear Data, then click Uninstall Clock Update.
(My son had the same problem and this seems to have cured it.)
Neither of these work for me...I've had to factory reset the phone more than once (as per att tech support) and nothing works. this is one of many issues with my s6 edge
It does not work for me on S5 whicheck started after the recent OS upgrade.
Any other solution will be appreciated
Gremlin69
