Universal car mount for use with TPU (or other) case?
I tried it on the dock for my Garmin Nuvi 260w and it fit like a glove, too. I have a feeling just about any dock for a 4.3" Nuvi will work.
Both my TPU case and my wife's purple case she bought at the Sprint Store fit well. I took it for a test drive down a gravel alley, no slippage at all. A pretty solid and cheap option. $8 bucks shipped from the US all over eBay. I'm buying another one for my wife's car.
Good looking out, Android Central.
Hey guys, Been going NUTS looking for a car mount for my E4GT! Does that Garmin holder turn so u can have it in Portrait and Landscape? Also any problems charging it at the same time? Just wanna know cuz it looks like that is the one Im going to go with!! I also have a TPU case and I seen u guys said it fits perfect with a TPU case so thats a major plus!!
I think you're right. The ebay listing that I bought from shows the mount bracket as the same for models:
200, 200W, 250, 250W, 260, 260W, 270, 205, 205W, 255, 255W, 265T, 265WT, 275T
It's a ball joint, so you can rotate and angle it to whatever position you want. The charge port isn't blocked, so there's no reason you can't plug power in while it's in the mount. In fact, I bought another one (suction cup version), to use on my desk as a desktop stand! ;)
Reactions: aaron130
I ordered my Nuvi mount from eBay. Great find!
I have an Epic 4G Touch and need some kind of mount for my car. How well did that Nuvi GPS mount fit? Are there any clearance issues when the phone is turned to the vertical/portrait position? Does it hit the windshield? If it is mounted on the dashboard instead of the windshield, can it be turned to the portrait position and plugged into the charger without any clearance problems? I ask because by the looks of the picture, it seems like it might cause the phone to hit when it is turned to portrait. Thanks for any help!
gurusdex
