Unlocked note 9 pie beta live
I got a Samsung+ notification about the S-Pen and when I went in to check that, I got the One UI Beta badge. I registered and within a few minutes it was available. Didn’t take long for me to fall in love.
Love the new UI
I even like the new icons. What do you think of the gestures? I'm forcing myself to use them and it's not bad to me but I'd used an iPhone X for about a year.
New icons I'm not crazy about but getting use to them lol
So I lost some of my AODs with Pie. I go to download the APK for the additional AOD and it wont download even though I have the security settings turned off.
I wish I waited for the actual version instead of being a test dummy for it lol but I bought into the hype.
It's beta meaning things will be broken until final release
yeah, some of my notifications are broken. volume is way low. what software version are you guys on that got the official beta?
ACK !!
I guess not surprisingly Goodlock no longer works :(
Is there anyway to revert back to where I was? Not quite ready to do that yet, but would like to know how if possible.
Other than factory reset...
I like One UI so much that I'm willing to put up with some extras not working. If there was something device crippling, I'd just use my 2 XL until the official release or an updated Beta.
Tip-
if anyone wants to go back oreo use smart switch. fastest way
if u want stay in the beta dont un register through the Samsung plus app and can go back and forth from beta to oreo
I done it. I had to go-to the play store and locate Samsung + app, then below that was an option to enroll in the beta version of the Samsung + app. That took ages to enroll. Once that was done I it updated the Samsung + app to the beta version. I launched the Samsung + beta and received the notification to enroll into the beta program . All done now.
Did you download Samsung plus beta ?
Good they still accepting
Ok I installed the beta and it seems ok but I uninstalled it cause I can't connect my Galaxy Watch.
Downloaded the new Samsung plus and don't see the option guessing I'm not unlocked, wasn't sure since I bought a phone off of eBay. Has to mean it's getting closer for everyone else.
Patience with these updates are everything. Let them work out the kinks first.
Ok I really REALLY HATE this.
I deregistered and thought that checking for a software update would download the last Oreo version... but it just keeps telling me that I have the latest.
How can I use smart switch if I didn't use it before upgrading?
I'm guessing my only option now is factory reset then reinstall everything all over again?
I'll go into why I hated it tomorrow, in the meantime I'd just like to know the easiest way to get back to Oreo.
Thanks.
Thanks.
First you made a mistake to deregister as you can go back and forth..now just simply plug in to smart switch and it will ask u do u want to to go back to latest oreo build for your device
Heritagesa01
